JMP Knowledge Base
Findings Time Trends in JMP® Clinical 8.0 might result in the error "There are no tests with measurements for at least two time points..."
Findings Time Trends in JMP Clinical 8.0 might result in this error message:
ERROR: There are no tests with measurements for at least two time points. Time Trends cannot be plotted.
The error appears even when there are time points available in the Analysis Data Model (ADaM) data sets.
Click here to access the Hot Fix for this issue.
[Previously JMP Note 67870]
Details
Operating System
Windows
Reported Version
8.0
Products JMP Clinical
