JMP Knowledge Base
Error when converting dates to character dates in JMP® Clinical 7.1
In JMP® Clinical 7.1 when the AE dataset is loaded and ASTDT and/or AENDT are converted to AESTDTC and/or AEENDTC, the length is not long enough, and all values of the character dates are incorrect. This issue is resolved in the hot fix found here.
If you encounter this problem and if the study was previously added with JMP® Clinical 7.1 before installing the hot fix in this note, you will need to first run "Refresh Study Metadata" on that study.
[Previously JMP Note 64955]
Details
Operating System
Windows
Reported Version
7.1
Fixed Version
8.0
Products JMP Clinical
