JMP Knowledge Base
Copying Graphs from JMP® GraphBuilder using Right-Click > Edit > Copy Graph may omit data points
Copying Graphs from JMP® Graph Builder using Right-Click > Edit > Copy Graph may omit data points in the pasted output.
There are three workarounds for this issue.
  1. You can use Ctrl-C to copy the graph. Ctrl-J will copy the complete graph to a journal as well.
  2. You can raise the Fast Marker Threshold in Graph Preferences so that Fast Marker Node is used to copy the complete graph. However, the copy process may be slower, and the display might change. This change will affect all graphs.
  3. You can right-click on the graph and change the Marker Drawing Mode from Fast to Normal. Then you can use Right-Click > Edit > Copy Graph to make the copy. This change will affect only this graph.
[Previously JMP Note 62813]
Details
Operating System
macOS Windows
Reported Version
14.1
Fixed Version
15.0
Products JMP Pro JMP
