JMP Knowledge Base
Clear Log() sometimes does not empty the contents of the log
The Clear Log() function is designed to clear the contents of the log.  At seemingly random times, the function does not actually clear the contents of the log. As a workaround, open a new script window and run Clear Log().
[Previously JMP Note 62603]
Details
Operating System
macOS Windows
Reported Version
14.0
Fixed Version
14.2
Products JMP JMP Pro
