JMP Knowledge Base
Can I test if my data are coming from the "XYZ" distribution?
Yes. This functionality is available in the Distribution platform. In the output window, select either Continuous Fit or Discrete Fit from the column's pull-down menu. Once the Fitted Distribution table is presented, choose Goodness of Fit from its pull-down menu.
[Previously JMP Note 36012]
Details
Operating System
macOS Windows
Products JMP JMP Pro
