JMP Knowledge Base
Can I perform a multinomial logit analysis in JMP®?
If you are using the term multinomial logit analysis to mean a logistic regression with more than 2 response levels, then yes. JMP® can fit a nominal response with generalized logits, as well as an ordinal response with cumulative logits.
Nominal and ordinal logistic regression analysis options are available under the Personality drop down under Analyze ► Fit Model.
[Previously JMP Note 35252]
Details
Operating System
macOS Windows
