JMP Knowledge Base
Can I get a pdf plot in JMP®?
Yes. Go to the Analyze menu and choose the Distribution platform. Specify a continuous Y column. Next, from the red triangle menu in the output window, choose Continuous Fit or Discrete Fit and fit the distribution of your choice.
[Previously JMP Note 35336]
Details
Operating System
macOS Windows
Products JMP JMP Pro
