JMP Knowledge Base
Can I get a Receiver Operating Characteristic (ROC) curve in JMP®?
Yes. Under Analyze ► Fit Model, construct a model such that the response column(s) is(are) modeled as Nominal or Ordinal, then select from one of several applicable Personality options, such as Nominal Logistic. Choose ROC Curve from the red triangle menu options under the model output. Note: ROC Curves are also available in other platforms in JMP, such as: Partition, Neural Net, and Discriminant.
[Previously JMP Note 35325]
Details
Operating System
macOS Windows
