JMP Knowledge Base
Can I get Kurtosis and Skewness statistics in JMP®?
Yes. From the Analyze ► Distribution window, choose a column of interest. In the output window, select Display Options ► Customize Summary Statistics from the column's pull-down menu.
(Note: Before JMP® version 10, these statistics are provided under Display Options ► More Moments).
[Previously JMP Note 35670]
Details
Operating System
macOS Windows
Products JMP
