JMP Knowledge Base
Can I build a model with higher order terms without centering those terms?
Yes, you can build a model with higher order terms without centering those terms. To turn off polynomial centering, click on the menu next to Model Specification in the Fit Model dialog and select Center Polynomials. This will remove the check mark and turn off the option.
[Previously JMP Note 37927]
Details
Operating System
macOS Windows
Products JMP JMP Pro
