JMP Knowledge Base
An "Error 101P" message appears when you are running the JMP® Pro updater
The following error message might appear when you are running a JMP Pro updater,
Figure 1Figure 1
Here are some possible reasons for this message:
  1. You have a JMP Annual License. You need to download the JMP Annual License updater instead from www.jmp.com/update.
  2. You have a JMP Subscription. You need to sign in to your JMP Subscription portal for the update.
  3. Your user account needs elevated rights on the machine. Try right-clicking the file and choosing Run as Administrator.
  4. A required folder is missing from your installation. You might need to re-install the base software.
If you are still unable to resolve the issue, contact JMP Technical Support.
[Previously JMP Note 68232]
Details
Operating System
Windows
Products JMP Pro JMP
