JMP Knowledge Base
An "Error 101A" message appears when you are running the JMP® Annual License updater
The following error message might appear when you are running a JMP Annual License updater:
Figure 1Figure 1
Here are some possible reasons for the message:
  1. You have a JMP® Pro installation. You need to download the JMP Pro updater instead from www.jmp.com/update.
  2. You have a JMP Subscription. You need to sign in to your JMP Subscription portal for the update.
  3. Your user account needs elevated rights on this machine. Try right-clicking the file and choosing Run as Administrator.
  4. A required folder is missing from your installation. You might need to re-install the base software.
If you are still unable to resolve the issue, contact JMP Technical Support.
[Previously JMP Note 68231]
Details
Operating System
Windows
Reported Version
16.1
Products JMP JMP Pro
