JMP Knowledge Base
An Adverse Events Distribution in JMP® Clinical 8.0 might result in an error when calculating relative risk
In JMP Clinical 8.0, an Adverse Events Distribution might result in the following error when calculating relative risk:
ERROR: More positional parameters found than defined.
This error can occur when values in the data contain commas.
Click here to access the hot fix for this issue.
[Previously JMP Note 67905]
Details
Operating System
Windows
Reported Version
8.0
Fixed Version
8.1
Products JMP Clinical
