JMP Knowledge Base
An Access Control Request pop-up message appears when you install JMP® on macOS
When you install JMP on modern versions of macOS, the following pop-up message is shown:
This message is a permissions prompt from macOS. Click OK to continue with the installation.
For more information about Folder Access Control in macOS, see the Control access to files and folders on Mac article.
If you need additional assistance, contact JMP Technical Support.
[Previously JMP Note 65612]
Details
Operating System
macOS
Reported Version
15.1
Products JMP
