JMP Knowledge Base
Alignment of column names is incorrect in standard safety reports in JMP® Clinical 8.0
In JMP Clinical 8.0, the column names in a standard safety report after the first column are not aligned with the data.
Click here to access the hot fix for this issue.
[Previously JMP Note 67864]
Details
Operating System
Windows
Reported Version
8.0
Fixed Version
8.1
Products JMP Clinical
