JMP Knowledge Base
A JMP® script might return the following warning: Cannot find FrameBox[ "ScatterPlot Matrix" ]
Due to a required change related to HelpKeys, scripts that are created in an earlier release of JMP and then run in JMP® 16.1 and later releases might result in the following log message:
Cannot find FrameBox[ "Scatterplot Matrix" ] at {}
In the Dispatch() section of the Scatterplot Matrix script, change the string "Scatterplot Matrix" to "Scatterplot Matrix Plot."  See the following example:
obj = dt << Scatterplot Matrix(
	Y( :height ),
	X( :weight ),
	Matrix Format( "Lower Triangular" ),
		Dispatch(
			"ScatterPlot Matrix", //Change to "Scatterplot Matrix Plot"
            FrameBox,
			{Row Legend(
				age,
				Color( 1 ),
				Color Theme( "JMP Default" ),
				Marker( 0 ),
				Marker Theme( "" ),
				Continuous Scale( 0 ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
[Previously JMP Note 68448]
Details
Operating System
macOS Windows
Reported Version
16.1
Products JMP JMP Pro
