JMP Knowledge Base
A JMP® Genomics 10.2 hot fix adds new features for the Basic Genetics Workflow process and Cross Evaluation process
This hot fix is intended for users of JMP® Genomics 10.0.
After the hot fix is applied, the Basic Genetics Workflow process now enables input data containing Non-delimited Genotypes, "/"-delimited Genotypes, or Numeric Genotypes.
Also, the Cross Evaluation process now includes the following capabilities:
  • Specifying multiple parents in the backcross analysis
  • Computing a similarity measure between progenies and recurrent parents
  • Selecting progenies based on the similarity to the recurrent parents
  • Specifying the number of progenies by using the list-style specification, so you can specify a different number of progenies per generation
  • Specifying an index cutoff by using the list-style specification, so you can specify a different cutoff per generation
  • Specifying a percentage cutoff by using the list-style specification, so you can specify a different cutoff per generation
[Previously JMP Note 68702]
Details
Operating System
Windows
Reported Version
10.0
Products JMP Genomics
