JMP Knowledge Base
A DSUR/PSUR report in JMP® Clinical 8.0 might result in the error "Name arg must be quoted string . . ."
In JMP Clinical 8.0, the DSUR/PSUR report might result in an error that is similar to the following:
Line XX Column YY: ... Grouping Columns( :Name(?Planned Treatment for Per...
This problem occurs when the Term Level and Group Level selections are set to the same term.
Click here to access the Hot Fix for this issue.
[Previously JMP Note 67910]
Details
Operating System
Windows
Reported Version
8.0
Products JMP Clinical
