The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Challenge 2
jmp-challenge-v2.pngThis month’s challenge is back to basics – finding prime numbers.
I am interested in two functions:
  1. getPrimes(n,t) – where n is a positive integer and t can be one of two values. If it is 1 getPrimes returns the first n primes. If it is 2 getPrimes will return all primes less than or equal to n. You can assume the value of n will not exceed 1e8.
  2. isPrime(vec) – where vec is a nRow row, 1 column matrix of integer values no greater than 4e14. It is to return a matrix of 1’s and 0’s where vec[i] = 1 indicates the ith element of vec is prime and 0 it is not prime. The input test vector will contain between 100 and 1000 elements (but the function should be able to accepts larger or smaller vectors).
Examples:
   getPrimes(10,1) would return [2,3,5,7,11,13,17,19,23,29]
   getPrimes(10,2) would return [2,3,5,7]
   isPrime([-1,0,2,4,5]) would return [0,0,1,0,1]
Scoring: 4 points for each function. 3, 2, and 1 point for the fastest solution (awarded separately for each function). 3 points if your solution is as fast or faster than the fastest submitted by a staff member.
Submission deadline is Friday. May 15, 11:59 pm Eastern Time.
Comments
landon
Super User (Alumni)
Thanks Don for the fun challenge. I remember when you were at our JMP Day event a few years back we did something similar to Challenge 1.
Cheers, Landon
DonMcCormack
@landon I remember it, too and it definitely influenced the first challenge.
MathStatChem
Level VII
for getPrimes(), the "assume  n will not exceed 1e8", is the for both t=1 and t=2?  I ask because I think finding the first 100 million primes might be a stretch for JMP.
DonMcCormack
@MathStatChem - yes, the limit is for both t=1 and t=2 is 1e8. The value I ultimately use for testing will depend on how quickly the submitted scripts run.
MathStatChem
Level VII
Nice website to use to check your results:  https://primes.utm.edu/nthprime/index.php
DavidLeber
Level III
How exactly do we post a solution? Just as a comment to this post?
DonMcCormack
@DavidLeber it's best if you send me the solution via email or private message on the Community. After the 15th, I'll have another post talking about the solutions.
