The New JSL Cookbook is finally here! It is a revamp of the old Cookbook to offer recipes that are more accessible and general.
On the main page, you’ll see four sections: Appetizers, Main Courses, Side Dishes, and Desserts. In general, the sections will go from basic to advanced. Appetizers will be used for recipes about fundamental tools in JSL, like Script Window and the Debugger. The focus won’t be on code writing but on things to help you write code better and faster. The center of attention in Main Courses will be JSL objects: tables, journals, platforms, etc., as well as basic input-output. While many of the operations in this section will become simpler as the Action Recorder develops, there will always be a need to tweak automatically generated code. Side Dishes gets into some of the nuts and bolts of JSL—things like looping, branching, error trapping, and so on. Recipes that take your JSL skills to the next level will be found here. Finally, the Desserts section will contain recipes going above and beyond everyday scripting. Here you’ll find items covering both advanced topics and JSL-based JMP applications, such as the Application Builder.
Here are the starting nine recipes in the Cookbook:
Appetizers
The Script Window – Basics
Using the Script Widow – Next Steps
Main Courses
Join 2 Tables and Create a Subset
Modify a Report Based on Analysis Results
Build a Tailored Report using Messages
Concatenate CSV Files Selected by User
Side Dishes
Using a Dialog Box to Create a Tailored Report
Desserts
Accessing Information using REST/API – Getting Started
Running a Platform without Knowing the Number of Names of Columns
Tags will be used to cross reference topics to recipes. Here is the current list:
Tag |
Recipes |
Enhanced Log |
The Script Window – Basics (Appetizers) Join 2 Tables and Create a Subset (Main Courses) Build a Tailored Report using Messages (Main Courses) |
Script Editor |
The Script Window – Basics (Appetizers) Using the Script Widow – Next Steps (Appetizers) |
Scripting Index |
The Script Window – Basics (Appetizers) Modify a Report Based on Analysis Results (Main Courses) Build a Tailored Report using Messages (Main Courses) |
Data Table Objects |
Join 2 Tables and Create a Subset (Main Courses) |
Colors |
Modify a Report Based on Analysis Results (Main Courses) |
Platform Objects |
Report Objects |
XPATH |
Input-Output |
Concatenate CSV Files Selected by User (Main Courses) |
Lists |
String Manipulation |
User Input |
Concatenate CSV Files Selected by User (Main Courses) Using a Dialog Box to Create a Tailored Report (Main Courses) |
Dialogs |
Using a Dialog Box to Create a Tailored Report (Main Courses) Accessing Information using REST/API – Getting Started (Desserts) |
Expression Handling |
Using a Dialog Box to Create a Tailored Report (Main Courses) Running a Platform without Knowing the Number of Names of Columns (Desserts) |
Associative Arrays |
REST/API |
The New Cookbook is meant to be a living document. In the coming months, we will be adding more recipes, tagged topics, and resource links. We will use this blog as a place to post questions and comments about the Cookbook.
We would also like to encourage you to submit your recipe to be included in the Cookbook. We'll ask for the completed code and recipe instructions, similar to what you currently see attached to the recipes. Please make your documents editable. There is no need to record yourself performing the recipe.
That’s it for now. Hope you enjoy. Bon Appetit!
