Collaborating With Data, Building Consensus: Julia O’Neill, Direxa Consulting, describes an ‘aha!’ moment when she led a team of scientists who collaborated with data and built consensus with analytics.
This is a modal window.
Beginning of dialog window. Escape will cancel and close the window.
End of dialog window.
This is a modal window. This modal can be closed by pressing the Escape key or activating the close button.
“The most important part was that the analytics allowed us to build consensus, and to start listening to the process technicians. So, the operators of the process had been saying all along what they saw and people just hadn't listened enough. But the data helped us all to focus on what they had been trying to tell us and so it was a very successful project.”
For more insights on building a culture of analytic excellence, watch this panel and case study.
