The JMP S3 Data Connector in the JMP® Marketplace uses JMP's powerful Python integration to provide seamless access to Amazon Web Services (AWS) S3. You can configure your AWS credentials within the data connector editor and quickly import files that are compatible with JMP and are hosted on Amazon S3 remote connections. This integration streamlines data retrieval processes, enhancing your workflow efficiency when working with cloud-hosted data.
To learn how to use the S3 Data Connector, watch the video:
This is a modal window.
Beginning of dialog window. Escape will cancel and close the window.
End of dialog window.
This is a modal window. This modal can be closed by pressing the Escape key or activating the close button.
You can try the S3 Data Connector add-in here.
