%3CLINGO-SUB%20id%3D%22lingo-sub-212561%22%20slang%3D%22zh-CN%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3EJMP%20rende%20la%20gestione%20dell'affidabilit%C3%A0%20pi%C3%B9%20efficiente%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-212561%22%20slang%3D%22zh-CN%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3ENegli%20ultimi%20anni%2C%20sempre%20pi%C3%B9%20aziende%20hanno%20iniziato%20a%20concentrarsi%20sul%20miglioramento%20dell'affidabilit%C3%A0%20dei%20loro%20prodotti.L'affidabilit%C3%A0%20%C3%A8%20diventata%20uno%20degli%20indicatori%20importanti%20per%20misurare%20la%20qualit%C3%A0%20del%20prodotto.L'affidabilit%C3%A0%20si%20riferisce%20alla%20probabilit%C3%A0%20che%20il%20prodotto%20esegua%20la%20funzione%20specificata%20entro%20il%20tempo%20specificato%20nelle%20condizioni%20d'uso%20specificate.Un%20problema%20riscontrato%20da%20molte%20imprese%20nell'implementazione%20della%20gestione%20dell'affidabilit%C3%A0%20%C3%A8%20che%20quando%20la%20gestione%20dell'affidabilit%C3%A0%20dei%20prodotti%20si%20sviluppa%20fino%20a%20un%20certo%20stadio%2C%20i%20metodi%20di%20modellazione%20statistica%20sono%20obbligatori%20e%20dal%20momento%20che%20il%20metodo%20di%20analisi%20statistica%20dell'affidabilit%C3%A0%20%C3%A8%20relativamente%20pi%C3%B9%20complicato%2C%20molti%20sono%20chiamati%20sei%20standard.%20I%20consulenti%20dei%20poveri%20maestri%20della%20cintura%20nera%20non%20osano%20toccarlo%20facilmente%2C%20il%20che%20invisibilmente%20proietta%20un%20misterioso%20velo%20sull'analisi%20dell'affidabilit%C3%A0.%3C%2FP%3E%0A%3CP%3EStudiando%20gli%20elementi%20di%20qualit%C3%A0%20dei%20prodotti%2C%20Zhu%20Lan%2C%20un%20guru%20della%20gestione%20della%20qualit%C3%A0%2C%20ha%20riassunto%20le%20varie%20caratteristiche%20qualitative%20e%20le%20ha%20divise%20in%20tre%20categorie%3A%20in%20primo%20luogo%2C%20caratteristiche%20tecniche%20come%20forza%2C%20durezza%2C%20tensione%2C%20ecc.%20Secondo%2C%20caratteristiche%20psicologiche%2C%20come%20Percezione%2C%20visione%2C%20gusto%2C%20ecc.%2C%20In%20terzo%20luogo%2C%20caratteristiche%20legate%20al%20tempo%20come%20affidabilit%C3%A0%2C%20manutenibilit%C3%A0%2C%20ecc.Questo%20dimostra%20che%20l'affidabilit%C3%A0%20%C3%A8%20una%20parte%20indispensabile%20del%20controllo%20di%20qualit%C3%A0.%3C%2FP%3E%0A%3CP%3E%26nbsp%3BMolti%20rinomati%20produttori%20di%20automobili%20lavorano%20da%20anni%20sull'affidabilit%C3%A0%20e%20GM%20%C3%A8%20una%20delle%20prime%20aziende%20a%20introdurre%20concetti%20di%20affidabilit%C3%A0%20per%20la%20progettazione%20e%20la%20produzione%20dei%20prodotti.Dopo%20un%20lungo%20periodo%20di%20lavoro%20di%20affidabilit%C3%A0%2C%20il%20livello%20di%20affidabilit%C3%A0%20di%20GM%20%C3%A8%20aumentato%20significativamente.Negli%20ultimi%20anni%2C%20il%20rapporto%20di%20indagine%20sull'assicurazione%20automobilistica%20nordamericana%20(VDS)%20rilasciato%20da%20JDPower%2C%20l'autorevole%20organizzazione%20di%20ricerca%20automobilistica%20negli%20Stati%20Uniti%2C%20mostra%20che%20il%20marchio%20Buick%20di%20GM%20%C3%A8%20da%20molto%20tempo%20nelle%20prime%20tre%20posizioni%20e%20le%20sue%20prestazioni%20sono%20molto%20stabili.%3C%2FP%3E%0A%3CP%3EOltre%20all'industria%20automobilistica%2C%20anche%20l'ingegneria%20dell'affidabilit%C3%A0%20%C3%A8%20ampiamente%20utilizzata%20in%20altre%20industrie%20manifatturiere.Tieni%20d'occhio%20la%20preziosa%20esperienza%20di%20aziende%20come%20Intel%20e%20Dow%20Chemical%20nell'integrazione%20degli%20strumenti%20di%20affidabilit%C3%A0%20nella%20catena%20di%20valore%20originale%20di%20R%20%26amp%3B%20S%2C%20produzione%20e%20utilizzo%20del%20sito%20della%20societ%C3%A0.Non%20%C3%A8%20difficile%20trovare%20uno%20dei%20fattori%20chiave%20per%20il%20successo%20%C3%A8%20quello%20di%20rendere%20l'affidabilit%C3%A0%20non%20%C3%88%20diventato%20uno%20dei%20preferiti%20di%20alcune%20%C3%A9lite%20di%20R%20%26amp%3B%20S%2C%20ma%20visualizza%20e%20semplifica%20l'analisi%20dell'affidabilit%C3%A0%2C%20rendendolo%20uno%20strumento%20ordinario%20che%20molti%20tecnici%20possono%20utilizzare%20e%20pu%C3%B2%20essere%20utilizzato%20per%20ottenere%20miglioramenti%20decisionali.%3C%2FP%3E%0A%3CP%3EIn%20tutta%20onest%C3%A0%2C%20%C3%A8%20abbastanza%20difficile%20raggiungerlo%20oltre%20un%20decennio%20fa.%20Il%20sentimento%20delle%20aziende%20ordinarie%20%C3%A8%20che%20l'affidabilit%C3%A0%20%C3%A8%20%22inaspettata%22.Tuttavia%2C%20il%20rapido%20sviluppo%20e%20la%20maturit%C3%A0%20della%20moderna%20tecnologia%20informatica%20negli%20ultimi%20anni%20ha%20consentito%20alle%20imprese%20di%20soddisfare%20le%20condizioni%20preliminari%20degli%20ostacoli%20tecnici%20tradizionali.Molti%20strumenti%20affidabili%20sono%20rappresentati%20da%20un%20software%20di%20controllo%20della%20qualit%C3%A0%20professionale%2C%20JMP%20ha%20creato%20un'analisi%20avanzata%20interattiva%20e%20visiva.%20La%20modalit%C3%A0%20presenta%20i%20vantaggi%20di%20una%20semplice%20operazione%20e%20un'elevata%20efficienza%20di%20analisi%2C%20che%20fa%20scendere%20l'affidabilit%C3%A0%20dell'altare%20verso%20la%20%22divulgazione%22.%3C%2FP%3E%0A%3CP%3ELe%20seguenti%20sezioni%20si%20concentreranno%20su%20diverse%20importanti%20direzioni%20delle%20applicazioni%20per%20l'analisi%20dell'affidabilit%C3%A0%20e%20l'aiuto%20dell'analisi%20di%20affidabilit%C3%A0%20della%20visualizzazione%20interattiva%20JMP.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%20l%20%3C%2FSTRONG%3E%3CSTRONG%3E%20Distribuzione%20dei%20dati%20di%20vita%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20%26nbsp%3B%20Nell'ingegneria%20dell'affidabilit%C3%A0%2C%20se%20i%20dati%20sulla%20vita%20del%20prodotto%20possono%20essere%20adattati%20a%20una%20certa%20distribuzione%20di%20probabilit%C3%A0%2C%20le%20caratteristiche%20di%20questa%20distribuzione%20possono%20essere%20utilizzate%20per%20prendere%20decisioni%20sulla%20valutazione%20del%20design%20e%20della%20produzione%20del%20prodotto.Tuttavia%2C%20la%20difficolt%C3%A0%20%C3%A8%20che%20i%20dati%20di%20affidabilit%C3%A0%20hanno%20una%20caratteristica%20limite%20e%20la%20sua%20distribuzione%20di%20probabilit%C3%A0%20%C3%A8%20molto%20pi%C3%B9%20complicata%20e%20pi%C3%B9%20difficile%20da%20comprendere%20rispetto%20alla%20distribuzione%20dei%20dati%20generali.Con%20l'aiuto%20del%20software%20JMP%2C%20gli%20ingegneri%20possono%20facilmente%20identificare%20la%20distribuzione%20dei%20dati%20di%20vita%20pi%C3%B9%20corrispondenti%20in%20pochi%20secondi%20semplicemente%20facendo%20clic%20con%20il%20mouse%20per%20trovare%20il%20tipo%20di%20distribuzione%20dei%20dati%20di%20vita%20pi%C3%B9%20corrispondenti%20in%20pochi%20secondi.%20Prevedere%20la%20vita%20utile%20del%20prodotto%2C%20la%20probabilit%C3%A0%20di%20guasto%2C%20la%20densit%C3%A0%20di%20probabilit%C3%A0%20di%20guasto%20e%20il%20tasso%20di%20guasto.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%A3%BD%E5%91%BD%E8%B3%87%E6%96%99%E5%88%86%E4%BD%88%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%A3%BD%E5%91%BD%E8%B3%87%E6%96%99%E5%88%86%E4%BD%88%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%A3%BD%E5%91%BD%E8%B3%87%E6%96%99%E5%88%86%E4%BD%88%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F17704i35EB798C69D135F8%2Fimage-dimensions%2F749x386%3Fv%3Dv2%22%20width%3D%22749%22%20height%3D%22386%22%20role%3D%22button%22%20title%3D%22%E5%AF%BF%E5%91%BD%E6%95%B0%E6%8D%AE%E5%88%86%E5%B8%83.jpg%22%20alt%3D%22%E5%A3%BD%E5%91%BD%E8%B3%87%E6%96%99%E5%88%86%E4%BD%88%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%A3%BD%E5%91%BD%E8%B3%87%E6%96%99%E5%88%86%E4%BD%88%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%A3%BD%E5%91%BD%E8%B3%87%E6%96%99%E5%88%86%E4%BD%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%A3%BD%E5%91%BD%E8%B3%87%E6%96%99%E5%88%86%E4%BD%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDistribuzione%20dei%20dati%20di%20vita%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%20l%20%3C%2FSTRONG%3E%3CSTRONG%3E%20Previsione%20di%20affidabilit%C3%A0%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Dopo%20aver%20compreso%20la%20distribuzione%20dei%20dati%20sulla%20vita%2C%20possiamo%20ulteriormente%20fare%20previsioni%20sull'affidabilit%C3%A0.JMP%20pu%C3%B2%20aiutarci%20a%20prevedere%20il%20numero%20di%20guasti%20in%20futuro.I%20futuri%20fallimenti%20possono%20essere%20stimati%20utilizzando%20grafici%20interattivi%20che%20modificano%20fattori%20come%20la%20produzione%20futura%20e%20la%20durata%20del%20contratto.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%8F%AF%E9%9D%A0%E5%BA%A6%E9%A0%90%E6%B8%AC%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%8F%AF%E9%9D%A0%E5%BA%A6%E9%A0%90%E6%B8%AC%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%8F%AF%E9%9D%A0%E5%BA%A6%E9%A0%90%E6%B8%AC%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F17705iB9915B50F704242A%2Fimage-dimensions%2F749x317%3Fv%3Dv2%22%20width%3D%22749%22%20height%3D%22317%22%20role%3D%22button%22%20title%3D%22%E5%8F%AF%E9%9D%A0%E6%80%A7%E9%A2%84%E6%B5%8B.jpg%22%20alt%3D%22%E5%8F%AF%E9%9D%A0%E5%BA%A6%E9%A0%90%E6%B8%AC%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%8F%AF%E9%9D%A0%E5%BA%A6%E9%A0%90%E6%B8%AC%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%8F%AF%E9%9D%A0%E5%BA%A6%E9%A0%90%E6%B8%AC%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%8F%AF%E9%9D%A0%E5%BA%A6%E9%A0%90%E6%B8%AC%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPrevisione%20di%20affidabilit%C3%A0%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3El%20test%20di%20vita%20accelerato%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20Se%20si%20desidera%20quantificare%20ulteriormente%20l'impatto%20che%20le%20diverse%20condizioni%20di%20carico%20possono%20avere%20sul%20prodotto%2C%20%C3%A8%20necessario%20utilizzare%20un%20metodo%20statistico%20che%20%C3%A8%20molto%20pi%C3%B9%20complicato%20rispetto%20all'analisi%20di%20regressione%20unidirezionale%20tradizionale.Il%20software%20JMP%20semplifica%20questo%20processo%20di%20analisi%2C%20trasformando%20complessi%20principi%20statistici%20in%20una%20serie%20di%20combinazioni%20grafiche%20che%20mostrano%20vividamente%20l'impatto%20di%20fattori%20di%20vita%20accelerati%20(come%20la%20temperatura%20in%20questo%20esempio)%20sulla%20vita%20del%20prodotto%20a%20diversi%20livelli.%20.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20style%3D%22width%3A%20750px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%8A%A0%E9%80%9F%E5%A3%BD%E5%91%BD%E8%A9%A6%E9%A9%97%22%20style%3D%22width%3A%20750px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%8A%A0%E9%80%9F%E5%A3%BD%E5%91%BD%E8%A9%A6%E9%A9%97%22%20style%3D%22width%3A%20750px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%8A%A0%E9%80%9F%E5%A3%BD%E5%91%BD%E8%A9%A6%E9%A9%97%22%20style%3D%22width%3A%20750px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F17707i4449F24861CC5E44%2Fimage-dimensions%2F750x416%3Fv%3Dv2%22%20width%3D%22750%22%20height%3D%22416%22%20role%3D%22button%22%20title%3D%22%E5%8A%A0%E9%80%9F%E5%AF%BF%E5%91%BD%E8%AF%95%E9%AA%8C.jpg%22%20alt%3D%22%E5%8A%A0%E9%80%9F%E5%A3%BD%E5%91%BD%E8%A9%A6%E9%A9%97%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%8A%A0%E9%80%9F%E5%A3%BD%E5%91%BD%E8%A9%A6%E9%A9%97%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%8A%A0%E9%80%9F%E5%A3%BD%E5%91%BD%E8%A9%A6%E9%A9%97%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%8A%A0%E9%80%9F%E5%A3%BD%E5%91%BD%E8%A9%A6%E9%A9%97%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ETest%20di%20vita%20accelerato%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%20l%20%3C%2FSTRONG%3E%3CSTRONG%3E%20Parametro%20modello%20di%20sopravvivenza%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20%26nbsp%3B%26nbsp%3BIn%20molti%20casi%2C%20non%20si%20tratta%20solo%20della%20temperatura%20e%20di%20una%20condizione%20di%20carico%20che%20influisce%20sulla%20vita%20del%20prodotto%2C%20ma%20anche%20su%20umidit%C3%A0%2C%20vibrazioni%2C%20radiazioni%2C%20pressione%2C%20sostanze%20chimiche%2C%20polvere%2C%20tensione%2C%20corrente%20e%20fattori%20umani.Come%20possiamo%20esprimere%20in%20modo%20completo%20ed%20intuitivo%20l'impatto%20di%20tutti%20i%20fattori%20sulla%20vita%20del%20prodotto%3FIn%20JMP%2C%20la%20soluzione%20a%20questo%20problema%20%C3%A8%20rappresentare%20accuratamente%20la%20relazione%20tra%20vari%20fattori%20di%20influenza%20(come%20rivestimento%2C%20temperatura%20Celsius%2C%20ecc.%20In%20questo%20esempio)%20e%20affidabilit%C3%A0%20del%20prodotto%20in%20un%20modulo%20%22descrittore%20di%20modello%22%20di%20facile%20comprensione.%20Prevedere%20in%20modo%20sincrono%20la%20probabilit%C3%A0%20di%20fallimento%20e%20la%20durata%20del%20prodotto%20in%20condizioni%20diverse.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20style%3D%22width%3A%20750px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%8F%83%E6%95%B8%E7%94%9F%E5%AD%98%E6%A8%A1%E5%9E%8B%22%20style%3D%22width%3A%20750px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%8F%83%E6%95%B8%E7%94%9F%E5%AD%98%E6%A8%A1%E5%9E%8B%22%20style%3D%22width%3A%20750px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%8F%83%E6%95%B8%E7%94%9F%E5%AD%98%E6%A8%A1%E5%9E%8B%22%20style%3D%22width%3A%20750px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F17708iC3DEAD5F450E92DA%2Fimage-dimensions%2F750x653%3Fv%3Dv2%22%20width%3D%22750%22%20height%3D%22653%22%20role%3D%22button%22%20title%3D%22%E5%8F%82%E6%95%B0%E7%94%9F%E5%AD%98%E6%A8%A1%E5%9E%8B.jpg%22%20alt%3D%22%E5%8F%83%E6%95%B8%E7%94%9F%E5%AD%98%E6%A8%A1%E5%9E%8B%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%8F%83%E6%95%B8%E7%94%9F%E5%AD%98%E6%A8%A1%E5%9E%8B%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%8F%83%E6%95%B8%E7%94%9F%E5%AD%98%E6%A8%A1%E5%9E%8B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%8F%83%E6%95%B8%E7%94%9F%E5%AD%98%E6%A8%A1%E5%9E%8B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EParametro%20modello%20di%20sopravvivenza%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%20l%20%3C%2FSTRONG%3E%3CSTRONG%3E%20Analisi%20dell'invecchiamento%20del%20prodotto%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BSe%20vogliamo%20avere%20una%20comprensione%20pi%C3%B9%20profonda%20delle%20caratteristiche%20di%20qualit%C3%A0%20del%20prodotto%2C%20non%20possiamo%20solo%20usare%20%22fallimento%22%2C%20%22nessun%20fallimento%22%20per%20indicare%20lo%20stato%20di%20qualit%C3%A0%20del%20prodotto%2C%20ma%20anche%20usare%20una%20variabile%20continua%20per%20descrivere%20i%20cambiamenti%20nelle%20caratteristiche%20del%20prodotto.Finch%C3%A9%20i%20dati%20rilevanti%20vengono%20registrati%2C%20gli%20ingegneri%20possono%20utilizzare%20JMP%20per%20eseguire%20un%20adattamento%20del%20modello%20pi%C3%B9%20accurato%20sul%20processo%20di%20invecchiamento%20delle%20caratteristiche%20del%20prodotto%20(come%20Corrente%20in%20questo%20esempio)%20in%20forma%20lineare%20o%20non%20lineare%20e%20prevedere%20il%20guasto%20del%20prodotto%20in%20base%20a%20ci%C3%B2.%20Il%20momento%20dell'evento%2C%20cos%C3%AC%20come%20la%20legge%20delle%20caratteristiche%20del%20prodotto%20nel%20tempo.%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E7%94%A2%E5%93%81%E8%80%81%E5%8C%96%E5%88%86%E6%9E%90%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E7%94%A2%E5%93%81%E8%80%81%E5%8C%96%E5%88%86%E6%9E%90%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E7%94%A2%E5%93%81%E8%80%81%E5%8C%96%E5%88%86%E6%9E%90%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F17709iC60D1270BDDFC23C%2Fimage-dimensions%2F749x589%3Fv%3Dv2%22%20width%3D%22749%22%20height%3D%22589%22%20role%3D%22button%22%20title%3D%22%E4%BA%A7%E5%93%81%E8%80%81%E5%8C%96%E5%88%86%E6%9E%90.jpg%22%20alt%3D%22%E7%94%A2%E5%93%81%E8%80%81%E5%8C%96%E5%88%86%E6%9E%90%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E7%94%A2%E5%93%81%E8%80%81%E5%8C%96%E5%88%86%E6%9E%90%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E7%94%A2%E5%93%81%E8%80%81%E5%8C%96%E5%88%86%E6%9E%90%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E7%94%A2%E5%93%81%E8%80%81%E5%8C%96%E5%88%86%E6%9E%90%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAnalisi%20dell'invecchiamento%20del%20prodotto%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%20l%20%3C%2FSTRONG%3E%3CSTRONG%3E%20Progettazione%20di%20esperimenti%20di%20affidabilit%C3%A0%20%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20%26nbsp%3B%20I%20dati%20dell'analisi%20dell'affidabilit%C3%A0%20derivano%20principalmente%20dal%20test%20di%20affidabilit%C3%A0%3A%20il%20test%20di%20affidabilit%C3%A0%20%C3%A8%20generalmente%20lungo%20e%20distruttivo%20per%20il%20prodotto.Per%20ridurre%20i%20costi%2C%20%C3%A8%20necessario%20utilizzare%20il%20minor%20numero%20di%20campioni%20sperimentali%20e%20il%20tempo%20sperimentale%20pi%C3%B9%20breve%20per%20ottenere%20il%20massimo%20delle%20informazioni.JMP%20%C3%A8%20un%20software%20che%20gode%20di%20una%20buona%20reputazione%20nel%20campo%20della%20progettazione%20sperimentale%3A%20gli%20ingegneri%20possono%20calcolare%20in%20modo%20flessibile%20e%20conveniente%20il%20numero%20e%20la%20lunghezza%20dei%20campioni%20necessari%20per%20condurre%20esperimenti%20di%20verifica%20dell'affidabilit%C3%A0%20e%20di%20verifica%20dell'affidabilit%C3%A0%20e%20possono%20anche%20stabilire%20un%20singolo%20fattore%20per%20considerare%20l'interazione%20tra%20fattori.%20(come%20la%20coppia%20in%20questo%20esempio%2C%20ecc.)%20o%20la%20combinazione%20di%20condizioni%20sperimentali%20nel%20test%20di%20durata%20accelerata%20a%20due%20fattori%20e%20il%20numero%20di%20campioni%20in%20ciascuna%20condizione%20sperimentale.%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20style%3D%22width%3A%20750px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%8F%AF%E9%9D%A0%E5%BA%A6%E5%AF%A6%E9%A9%97%E8%A8%AD%E8%A8%88%22%20style%3D%22width%3A%20750px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%8F%AF%E9%9D%A0%E5%BA%A6%E5%AF%A6%E9%A9%97%E8%A8%AD%E8%A8%88%22%20style%3D%22width%3A%20750px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%8F%AF%E9%9D%A0%E5%BA%A6%E5%AF%A6%E9%A9%97%E8%A8%AD%E8%A8%88%22%20style%3D%22width%3A%20750px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F17710iFD4E7C0189292BE4%2Fimage-dimensions%2F750x582%3Fv%3Dv2%22%20width%3D%22750%22%20height%3D%22582%22%20role%3D%22button%22%20title%3D%22%E5%8F%AF%E9%9D%A0%E6%80%A7%E5%AE%9E%E9%AA%8C%E8%AE%BE%E8%AE%A1.jpg%22%20alt%3D%22%E5%8F%AF%E9%9D%A0%E5%BA%A6%E5%AF%A6%E9%A9%97%E8%A8%AD%E8%A8%88%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%8F%AF%E9%9D%A0%E5%BA%A6%E5%AF%A6%E9%A9%97%E8%A8%AD%E8%A8%88%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%8F%AF%E9%9D%A0%E5%BA%A6%E5%AF%A6%E9%A9%97%E8%A8%AD%E8%A8%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%8F%AF%E9%9D%A0%E5%BA%A6%E5%AF%A6%E9%A9%97%E8%A8%AD%E8%A8%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EProgettazione%20di%20esperimenti%20di%20affidabilit%C3%A0%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-212561%22%20slang%3D%22zh-CN%22%3E%3CP%3ENegli%20ultimi%20anni%2C%20sempre%20pi%C3%B9%20aziende%20hanno%20iniziato%20a%20concentrarsi%20sul%20miglioramento%20dell'affidabilit%C3%A0%20dei%20loro%20prodotti.L'affidabilit%C3%A0%20%C3%A8%20diventata%20uno%20degli%20indicatori%20importanti%20per%20misurare%20la%20qualit%C3%A0%20del%20prodotto.L'affidabilit%C3%A0%20si%20riferisce%20alla%20probabilit%C3%A0%20che%20il%20prodotto%20esegua%20la%20funzione%20specificata%20entro%20il%20tempo%20specificato%20nelle%20condizioni%20d'uso%20specificate.Un%20problema%20riscontrato%20da%20molte%20imprese%20nell'implementazione%20della%20gestione%20dell'affidabilit%C3%A0%20%C3%A8%20che%20quando%20la%20gestione%20dell'affidabilit%C3%A0%20dei%20prodotti%20si%20sviluppa%20fino%20a%20un%20certo%20stadio%2C%20i%20metodi%20di%20modellazione%20statistica%20sono%20obbligatori%20e%20dal%20momento%20che%20il%20metodo%20di%20analisi%20statistica%20dell'affidabilit%C3%A0%20%C3%A8%20relativamente%20pi%C3%B9%20complicato%2C%20molti%20sono%20chiamati%20sei%20standard.%20I%20consulenti%20dei%20poveri%20maestri%20della%20cintura%20nera%20non%20osano%20toccarlo%20facilmente%2C%20il%20che%20invisibilmente%20proietta%20un%20misterioso%20velo%20sull'analisi%20dell'affidabilit%C3%A0.%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-212561%22%20slang%3D%22zh-CN%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3ECavo%20JMPer%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Ritalv
JMP讓可靠度管理更高效
近年來,越來越多的企業開始注重提升產品的可靠度。可靠度已經成為衡量產品品質的重要指標之一。所謂可靠度是指在規定的使用條件下,規定的時間內產品完成規定功能的機率。很多企業在實施可靠度管理時碰到的一個問題是當產品的可靠度管理發展到一定階段,必定會用到統計建模方法,而由於可靠度統計建模方法相對更複雜,很多號稱六標準差黑帶大師的諮詢師都不敢輕易碰它,這無形中給可靠度分析蒙上了一層神秘的面紗。
品質管理大師朱蘭在研究產品的品質元素時,曾將各種不同的品質特性歸納總結,分為三個大類:第一,技術特性,如強度、硬度、電壓等;第二,心理特性,如知覺、視覺、味覺等;第三,與時間相關的特性,如可靠度、可維修性等。由此可見,可靠度是品質管制中不可或缺的重要內容。
 許多知名汽車廠家已開展可靠度工作多年,通用公司就是最早引入可靠度概念進行產品設計生產的公司之一。經過了長期的可靠度工作開展後,通用汽車的可靠度水準顯著上升。最近幾年美國權威汽車研究機構J.D.Power公佈的北美地區汽車車輛可靠度(VDS)調查報告顯示,通用汽車旗下別克品牌長期位居三甲,表現非常穩定。
除了汽車行業,可靠度工程在其他製造業內也有廣泛的應用。留心觀察英特爾、陶氏化學等公司將可靠度工具融入企業原有的“研發、生產和顧客現場使用”價值鏈中的寶貴經驗,不難發現,其成功的關鍵因素之一就是讓可靠度不再成為少數研發精英的專寵,而是將可靠度分析視覺化、簡單化,使之成為眾多技術人員都可以使用的尋常工具,可以從中獲取決策依據的改善利器。
平心而論,十幾年前,要實現這一點還是具有相當難度的,普通企業的感覺是可靠度“可望而不可及”。然而,近年來現代電腦技術的迅猛發展和成熟使企業具備了跨越傳統技術障礙的前提條件,以專業品質管制統計軟體JMP為代表的諸多可靠度工具載體,開創了互動性、視覺化的先進分析模式,兼具操作簡易、分析高效的優點,讓可靠度走下神壇,走向“平民化”。
下面將著重介紹可靠度分析的幾個主要應用方向,以及JMP互動式視覺化的可靠度分析帶給企業的幫助。
l   壽命資料分佈
    在可靠度工程中,如果能夠將產品的壽命資料擬合為某一機率的分佈,就可以利用這個分佈的特性進行產品設計、製造的評估決策。但是困難的是,可靠度資料存在著設限特性,其機率分佈比一般資料的分佈擬合要複雜得多,也難理解得多。而借助JMP軟體,工程師只要輕鬆點擊滑鼠,即可在幾秒內從Weibull、對數正態、指數等十餘種分佈中進行智慧識別,尋找出最匹配的壽命資料的分佈類型,以便我們精確地預測產品的使用壽命、失效機率、失效機率密度和故障率等。
壽命資料分佈壽命資料分佈
l   可靠度預測
     在瞭解壽命資料的分佈情況之後,我們還可以進一步做可靠度預測。JMP可以幫助我們預測將來失效的次數。使用互動式圖形,調整將來產量和契約期限之類的因子,就可以估計將來的失效。
可靠度預測可靠度預測
l  加速壽命試驗
  如果想進一步量化地了解不同的負載條件可能對產品產生的影響,則需要用到比傳統的一元回歸分析要複雜得多的統計方法。JMP軟體將這個分析過程化繁為簡,把複雜的統計學原理轉化為一系列圖形組合,栩栩如生地展現出加速壽命因子(如本例中的溫度等)在不同水準時對產品壽命的影響程度。
加速壽命試驗加速壽命試驗
l   參數生存模型
    很多情況下,影響產品壽命的還不僅僅只有溫度一個負載條件,還可能包括濕度、振動、輻射、壓力、化學物質、沙塵、電壓、電流和人為因素等。怎樣才能綜合、直觀地表現所有因素對產品壽命的影響呢?在JMP中,這個問題的解決方案是用一種簡單易懂的“模型刻畫器”形式來精確地表現各個影響因素(如本例中的塗層、攝氏溫度等)與產品可靠度的關係,暫態同步地預測不同條件下的失效機率和產品使用壽命。
參數生存模型參數生存模型
l   產品老化分析
     如果要對產品的品質特性有更加深入的認識,我們不能僅僅用“失效”、“沒有失效”來表示產品的品質狀態,還要盡可能用一個連續變數來描述產品的特性變化。只要記錄了相關的資料,工程師使用JMP就能通過線性或非線性形式對產品特性(如本例中的Current等)的老化過程進行更加精確的模型擬合,並以此為基礎預測產品失效的發生時間,以及產品特性隨時間變化的規律。
產品老化分析產品老化分析
l   可靠度實驗設計
    可靠度分析的資料主要來源於可靠度實驗,可靠度實驗的時間一般較長,而且對產品都有破壞性。為了降低成本,我們需要用最少的實驗樣品、最短的實驗時間來最大限度地獲取資訊。JMP是一款在實驗設計領域享有聲譽的軟體,工程師可以靈活方便地計算開展可靠度檢驗實驗和可靠度驗證實驗所需的樣本數量和時間長度,還可以設置開展考慮因子間交互作用的單因子(如本例中的扭矩等)或雙因子加速壽命實驗時的實驗條件組合,以及計算每種實驗條件下的樣本數量。可靠度實驗設計可靠度實驗設計
Last Modified: Jun 12, 2019 7:12 AM
