  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
JMP Blog
J_Marquardt
Level VII
Find inspiration from past Discovery Summit presenters
What would you present if given the opportunity?What would you present if given the opportunity?We’ve seen thousands of presentations over the history of Discovery Summit. Even if you attended every single event, there is no way you would have seen each paper and poster. That’s why we’ve archived them for you in the JMP User Community, dating back to Discovery Summit 2010 at SAS world headquarters.
We encourage you to check them out. You’ll find a lot of ideas for applying JMP in your line of work, but you may also find inspiration to present a paper or e-poster of your own.
If you do, consider entering the Discovery Summit Munich 2020 call for content. User-led breakout sessions and e-poster presentations are cited as the primary reason people attend the conference series.
Once you decide to enter the call for content, it’s as easy as one, two, three:
Step 1: Submit an abstract that describes how you solved a real-world problem with the strategic implementation of analytics in JMP. Do this by Friday, 25 Oct. at 17:00 CEST.
Step 2: The steering committee will deliberate and announce selections in November.
Step 3: If you’re chosen, make plans to attend (and present) at Discovery Summit Munich 2020, 10-12 March.
Last Modified: Aug 6, 2019 4:15 PM
