JMPer Cable Blog
Do you want to learn the JMP Scripting Language?
JSL_guide.pngDo you think you could benefit from a JMP script but just don’t have the time to figure it out? JMP scripts put you in charge. A script can help you save time from repetitive analyses, ensure your analysis process is followed explicitly, and provide a method for demonstrating all the steps leading to your results. Sounds great, right?
Here are some of the ways that you can get started with the JMP Scripting Language (JSL) today:
  • On-Demand Webcasts. On the JMP website are on-demand webcasts from the Mastering JMP Series. This series covers topics designed to help you enhance your JMP skills. Specifically, the Application Development section includes links to videos for a variety of skill levels. The webcast titled Automating Analyses Using JMP Scripts is a great place to begin learning basic techniques of JSL.
  • Training Courses. JMP Scripting Language courses are offered by our training department. Taught by JMP experts, the following classes are available both in classrooms and in live web format:
  • JMP User Community. The JMP website hosts a User Community. In the File Exchange area of the User Community, you can find user-submitted script samples or JMP Add-Ins that might do exactly what you need. Join the Discussion forum where there are always JMP experts willing to answer your questions to help guide you.
  • Scripting Index. Accessible from the Help menu within JMP (Help > Scripting Index), the Scripting Index is probably the most utilized tool for scripters of all experience levels. Scroll down to and select an object that you are working with. The Items list will contain all the messages appropriate for that object. As you select messages in the Items list, the right side of the window will be updated with the generic syntax, a brief description, and an example script that can be run directly from the Scripting Index window.
  • Documentation. Below is a list of PDF books that are available in the online documentation:
    • Scripting Guide: The Scripting Guide is the original document of the JMP Scripting Language.
    • JSL Syntax Reference: The JSL Syntax Reference provides important details regarding syntax, arguments, and return values for JSL functions and messages.
  • Books. In addition to the documentation, there are two other books available that can help you get started:
  • JMP Partners. Our partners are teachers, consultants, industry experts and JMP scripters. Each has been certified by JMP Product Managers, which means that we are proud to call them partners, and our users can be confident in the services they provide.  Whether you are looking for mentoring or consulting services, take a look at the JMP Partner page.
So what are you waiting for?? Let’s get started with scripting!
Last Modified: Jan 3, 2023 12:56 AM
Comments
