JMP Add-Ins
Download and share JMP add-ins
Tools for Battery Analysis
This add-in contains tools for the analysis of data from Electrochemical Impedance Spectroscopy (EIS). It wraps functionality from the Python Package Impedance.py.
After installing the add-in, run the attached script once to install the requisite Python Packages.
This add-in uses the Python integration tools in JMP 18, it will not work in earlier versions.
This add-in is still in active development. Please contact @Jordan_Hiller  with questions and feedback.
version 0.1: Original
version 0.2: Added Kramers-Kronig analysis
Comments
ddmiller
What is the syntax or format for "model string"? Is there some documentation on this? Thanks!
