Browse apps to extend the software in the new JMP Marketplace
Sunburst Plot / Nested Pie Chart
vince_faller
Super User (Alumni)
I had a need to make a sunburst plot and thought that you wonderful people might enjoy it as well.
Basically it allows the user to select multiple columns in the X value of a pie chart and will slice within slices of the layer before it.
For instance, if I want to compare the heights of all people in each age group in big class.
Would give me a return of this.
Or I could also want sex in there.
Comments
This is awesome - Thanks!!
ezorlo
Very good tool
i need some customization, hope JMP will add layered pie charts as an option in the graph builder
@ezorlo what kind of customization?
ezorlo
Hi vince
1) changing color scheme (right now i use "row label color")
2) matching colors from the same categories across plots (right now i do it manually)
3) adjusting size and dimensions of the plot (i cant find a way)
4) adjusting label position (i change the numbers in the script)
Some of these I kind of managed but its very manual
thanks
