This add-in combines a number of visualizations related to consumer analytics, including Spider Plots, a multivariate plot on normalized values (riffing on @danschikore's RadViz add-in), a parallel plot, and pairwise correlation analysis. The add-in installs as "Parker Analysis" (e.g. Peter Parker) under the add-in menu.
The setup is straight forward - just drop the variables of interest into the variables field and the sample/person/product ID in the Label field. A summarized version of the Candy Bar Nutrition sample data set is included to demonstrate the table set up.
Since collected data can sometimes not extend the full width of an available scale (i.e. possible values ranged between 1 and 7, but observed values only ranging between 2 and 4) the platform has an option to use the Axis column property. Select the checkbox in the lower left of the launcher and the tool will scan the variables for Axis settings and scale those parts of the Spider plot accordingly.
Comments, complaints, and thoughts for improvement are always welcome!
Updates:
19May2020: Switched from adhoc parallel plot to using Graph Builder's Parallel Plot and added a bar chart with a column switcher.
