This Add-In creates an easy interface to some of the most common sensory tests: Triangle Test, Duo-Trio Test, Paired Comparison, and 2-Out-Of-5 tests.
Each of these is a chi-squared tests of proportions, with a given pair of probabilities for a "right" answer under the null hypothesis that the samples are not different. An example test for the Triangle Test and the original script are included with the Add-In.
The data table should contain a binary column to be tested. This column must have the Modeling Type Nominal. For best results with the Triangle Test and 2-Out-Of-5 Tests, assign a value label with Yes/No or Correct/Incorrect to ensure that the porportions are assigned properly.
The JMP documentation shows an example of the Test of Proportions.
