This add-in allows you to quickly and easily create a Scoping design within JMP, and visualise its results. Scoping designs can be an extremely efficient way of gathering simple but powerful information, prior to embarking upon a formal Screening design.
In just 4-6 experiments you can confirm:
A Scoping design will not tell you which factors are important, whether there are interactions or provide any formal statistics - but they can still be a valuable first step in a sequential DoE strategy, if little is known about the process.
For further information on Scoping designs please visit our website: http://www.prismtc.co.uk/scoping-designs
Hi Andrew,
I really like what you did there!
Any chance you add the "Pattern"-column to the design? Even for small designs like these ones I like to see what kind of experiment I am doing on the very first glance!
Regards,
Sebastian
Hi Sebastian,
Thanks for the feedback, and that's a great idea about adding the Pattern column! I'll include that in my next version of this tool.
Best regards,
Andrew
