Runs Test (Wald-Wolfowitz Test) and JSL Implementation of JMP Platform Dialog Box
txnelson
An implementation of the Wald-Wolfowitz Test, more commonly called a Runs Test.  This is a translation from a SAS Sample 33092 from http://www.sas.com website. It's output is a Run Chart (Control Chart) and a Results Table that contains the particulars from the Runs Test.
Also contained in the JMP Addin is a JSL implementation of an approximation of the user input dialog box used by most of the JMP Platforms.
It is a piece of JSL that can easily be stripped out and implemented in user's code
Comments
recremekim
This doesn't appear to work if you select the median.11759_JMP Runs Test for Median.jpg
50 data points used
2.86183
7.68534
6.69476
5.69521
1.64778
2.48436
2.46675
3.75411
1.35445
2.71276
3.47636
1.08042
1.19898
3.26590
0.25385
0.32216
1.45118
4.87050
6.26643
4.74128
4.13786
1.24669
4.53740
2.68636
2.32268
1.02866
2.12435
5.85016
3.48550
0.25086
2.36367
4.42492
3.81540
0.48526
2.69943
8.78881
2.20214
0.19546
4.28811
1.19588
5.15606
0.74346
0.59323
2.58602
4.29810
1.95153
1.06895
3.11554
0.83567
1.33004
txnelson
I have fixed the bug....thanks for finding it.  I will be uploading it shortly
recremekim
Works fine now. Data is Chi-sq. with 3 deg. of freedom.  Thanks
Would it be possible to add tests for trends, mixtures, length of runs, etc.?
Jim, a professor using 10.2 would like to use this add-in, but it won't load for him.  Is there a version of this add-in (or the script) that will run in 10.2?
Thanks!
Mia
Hi Jim,
The professor was able to open the add-in in edit mode in JMP 10.2, make some modifications, and save it.  It now works for him in 10.2.
Thanks!
Mia
txnelson
Mia,
I am glad the professor got the addin to work.
Jim
