An implementation of the Wald-Wolfowitz Test, more commonly called a Runs Test. This is a translation from a SAS Sample 33092 from http://www.sas.com website. It's output is a Run Chart (Control Chart) and a Results Table that contains the particulars from the Runs Test.
Also contained in the JMP Addin is a JSL implementation of an approximation of the user input dialog box used by most of the JMP Platforms.
It is a piece of JSL that can easily be stripped out and implemented in user's code
