Read our JMP Blog to learn more about the value and usage of this add-in.
Requirements:
- data table with measured depth, azimuth, and inclination
- optional: well name tags
The well trace add-in will:
- Allow user to designate measured depth, azimuth, and inclination as inputs
- Calculate Delta North, Delta East, and Total Vertical Depth (TVD)
- Allow user to apply appropriate units (feet or meters, NOTE: this is a label only)
- Optional: User may enter inclination and azimuth in radians
- generate a 3D scatterplot of well(s)
- If run subsequently, user will be asked if they want to keep or overwrite the previous run's new data
- If chosen to keep the previous data, the previous data column headers will be marked "_old"
