Browse apps to extend the software in the new JMP Marketplace
Outline Box Text Wrap Tool
notoriousapp
Problem Statement: Long column names result in graph Outline Boxes which are excessively long.  These wide Outline Boxes are a nuisance when pasting graphs into Powerpoint, etc.  It's not an issue to manually adjust the text wrap for 1-2 graphs but this is not an effective method when we have several graphs which need to be modified.  We intended to create an Add-in which would allow the user to customize the length of the text wrap in the Outline Box.
Simply generate your graphs, run the Add-in and select the value for the text wrap which is most visually appealing for you, sit back and feel like a boss for not having to spend time manually changing your text wrap or showing crappy copy/paste graphs in your presentation.
Credit goes to @Justin_Chilton for developing this script for me.
