This hybrid between traditional optimal designs and central composite designs gives you superior ability to estimate quadratic terms while retaining the flexibility of optimal designs with run size, model specification, and the ability to easily incorporate categorical factors. This is made a possible through a simple modfication to the coordinate exchange algorithm.
Add-in includes the ODA generator application and a user guide.
This add-in is the subject of a presentation at the upcoming 2018 Discovery Summit at SAS Headquarters. An article on this subject has also been accepted to the Journal of Quality Technology, but will not appear in print until 2019.
Wonderful work!!
Upon using jmpapp v1.0 file and the jmpaddin (add-in), I found some basal values that appears as -0.0006* or -0.0004* instead of 0 and I noticed that this was fixed in jmpapp v1.1 file.
So, could you kindly update the jmpaddin file (add-in)?
For seeking perfection, it will be great to add built-in computational options for:
1. α values for rotatability, orthogonality or user defined (custom).
2. Inscribed design.
3. Number of central points.
4. Blocking.
This add-in appears to have been created in 2018. Have there been any updates to this add-in?
