This Add-In gives you a menu of shortcuts to run JMP analyses related to the DMAIC Six Sigma process. It is organized to let you select tools and features that support each phase of the methodology. It includes links to Sample Data used to show how to use JMP to make data-driven decisions related to process improvement.
The Modern Six Sigma Add-In uses a JMP Project structure to organize your work and was created using JMP 18.
hi @lkimhui
Which scientific references were used to build the DMAIC Six Sigma process as an add-in to the jmp?
regarding
Hi @Raaed,
Six Sigma DMAIC is a data-driven quality strategy, you may find more information about the methodology from ASQ.
https://asq.org/quality-resources/dmaic
The same link was bundled in the Add-In as well.
After installing the Add-In, you may reach to the same link under JMP Menu > Modern Six Sigma > References.
Hope this helps.
Might be a dumb question but how do you install this add-in? Will it run in JMP 17?
Never mind saw the link and the tool has been added.
