This add-in will randomly make a melody based on some options you set, then your Mac will beatbox it to you. (Only works on Mac.)
The options are filled in with default values so Steps 1-5 are optional.
Looking forward to trying this on Monday! Interesting use of the JSL speak function. It looks like MAC has a grammar that can be embedded into the speak string to control pitch, among other things. Did you find a good resource for learning this? (It runs on windows, but Microsoft Anna just reads the numbers that should be controlling the pitch.)
Monday: very cool.
Thanks Craige. I'm trying to do things with JMP that people don't usually think of. It's silly (in a good way!) but it pushes the envelope.
Jeff Moore
