Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
Informative Missing Coding
John_Sall
Create formula columns to code for missing values
Informative Missing is a great feature in Fit Model in JMPPro, but to do the same without JMP Pro you need to make some formula columns. This add-in makes it easier to do. The idea is to be able to fit using columns that have missing values, and rather than imputing the missing value, you can using a coding system to make it predictive as missing.
Comments
mgc
Thanks to the new  AAAS Fellow for his JMPer Cable article on the benefits of this addin  http://www.jmp.com/about/newsletters/jmpercable/pdf/29_summer_2014.pdf
JimHartwig
This add-in makes the effort to get this information much quicker than the manual way I had to perform in JMP.
