Using multiple versions of JMP at the same time can be confusing because all windows have the same icons.
In addition, Windows often sends an open data file to the wrong JMP version for opening.
To make it easier to work with multiple JMP versions, install the add-ins and you will see in each JMP window which one is JMP 17, JMP18, JMP19:
Add-in developed and tested using the following system configuration.
Windows
JMP 17.2
JMP 18.0.1
JMP 19 EA1
Thanks Experts!
How can I uninstall it?JMP 18
I can distinguish different versions through this distinctive custom toolbar.
Cool idea! One small helpful fix the JMP folks could do is have Early Adopter version toolbar icons be a different color, to better differentiate if I have a production version and an EA open at the same time. I like how when you're in the various menu items you see the Early Adopter listed on the output to help, but the icon color can be an even easier differentiator.
Note - I had formally requested this with 'jmpbeta' as case number 00217120
