  • Browse apps to extend the software in the new JMP Marketplace
  • This add-in is now available on the Marketplace. Please find updated versions on its app page
JMP Add-Ins
Download and share JMP add-ins
Graph Builder Toolbar
Purpose
If you use Graph Builder often, the Graph Builder toolbar extension will help you by adding helpful shortcuts to the report toolbar.
For more details, please visit the JMP Marketplace.
Comments
hogi
hogi
Improved functionality of  Send To PPT:
  1.  CTRL +  click on the image in PPT to open again the corresponding JMP file
  2.  a table script is added which can be used to create again the same graph
    [to find the right table script, please go to PPT and check the Alternative Text]
hogi
I submitted the AddIn some days ago.
- pending review process ...
hogi
got approved.
-> new version is available now.
hogi
new version available - with 2 new features:
     talk to enhanced log (robust scripts from subset/summary tables )
    Graph Builder y=x Line Not Tied to Specific Graph
hogi
#DACH2024
hogi
to get access to the first part of the icons, the display language has to be set to English.
Some Functions change their internal name with the language
hogi
hogi
Hi Petra, I just downloaded the version from the marketplace and tested it on my system.
Hm, at least no general bug ...
the Addin uses the PNG clipboard option.
Could you please go to the preferences and check if it is activated:
Unfortunately, this is one of the few settings in the preferences which cannot be accessed via JSL : (
If this doesn't fix the issue, could you please check the log (CTRL + L) for some hint.
If you send me a private message, I can provide you a beta of the next version - with new functionality like "Graph Builder Remote Control" which allows the user to adjust colors, line styles and more just with some mouse clicks:
Maybe this update fixes your issue as well  ...
hogi
A new version is now available from JMP marketpace.
one of the new features: Graph Builder Remote control
it provides an easy to use interface to quickly adjust the settings of Graph Builder Plot.
please watch the video on the marketplace page to get an impression what you can do with it:
hogi
Important: if adjusting settings doesn't have an impact on the graph, the tool might be out of sync with the Graph Builder Plot.
After adding/removing entries from the plot, please use one of these buttons to get is synced:
