Graph Builder Toolbar
hogi
Level XII
Purpose
If you use Graph Builder often, the Graph Builder toolbar extension will help you by adding shortcuts to the report toolbar so that you can
  • Open and close the Control Panel
  • Toggle the legend on and off
How to Use
additional shortcuts Icons:
  • Control Panel on/off. Toggle the Control Panel mode on/off (makes point plots much nicer)
  • Legend on/off. Toggle the legend display on/off.
  • steal this code (beta mode): robust scripts from subset/summary tables - talk to enhanced log
  • reset axis labels if they were manually edited
  • outlines: toggles outlines for point plots and contour for heatmap plots on/off
  • Hierarchical X labels
  • LocalDataFilter -> subset: opens the current selection as a subset (= Show Subset)
  • Send to PPT. Shortcut to send the graph to an open Powerpoint presentation
    (Requires an open Powerpoint presentation)
  • animate LDF: adds an animation menu and saves the graphs as images to tmp folder
  • gradient: middle 90% (toggles it on/off)
    new: warning message
  • Linecut generate a linecut from a heatmap plot. Development and documentation of the code via the Community: Line Profile in JMP?
  • Cycle Group X/Y/Wrap Font Size. Change the font size of Group X/Group Y/Wrap labels
    implementing @ms's idea from Reduce font size for wrapped graph builder headings?
    Unfortunately, this is possible via hacking the Preferences!
    Here is a wish from 2019 to fix it in the future: Right-click to change Group font and font size
Note: I like it to have the report toolbar on the left of the window. To get it there, just right-click the toolbar and select Location > Left.
System Configuration
Add-in developed and tested using the following system configuration.
Windows
JMP 16
JMP 17
JMP 18
JMP 19
Special Considerations
PowerPoint is required to use the send to PowerPoint toolbar item. This requires a call to the operating system using the JSL function Run Program.
PowerShell is required to use the send to PowerPoint toolbar item.
Special Thanks
@jthi : Thanks for your great suggestions
Comments
hogi
hogi
Improved functionality of  Send To PPT:
  1.  CTRL +  click on the image in PPT to open again the corresponding JMP file
  2.  a table script is added which can be used to create again the same graph
    [to find the right table script, please go to PPT and check the Alternative Text]
hogi
I submitted the AddIn some days ago.
- pending review process ...
hogi
got approved.
-> new version is available now.
hogi
new version available - with 2 new features:
     talk to enhanced log (robust scripts from subset/summary tables )
    Graph Builder y=x Line Not Tied to Specific Graph
hogi
#DACH2024
