This Add-in will copy the script of the selected column(s) to the system clipboard. When pasted into a script window and run, the copied script will recreate the original column(s), including all properties (formula, value ordering, etc). This can be useful to move formula columns from one table to another (assuming the necessary columns are available for the formula to operate on).
