JMP Add-Ins
Download and share JMP add-ins
A basic text importer for Data Interchange Format (DIF) files
This add-in will create a JMP data table from a Data Interchange Format or DIF file.  The file format originated from Visicalc in the 1980 as a mechanism to transfer data between spreadsheet programs.
In the example code, I provide 4 mechanisms to check for the required headers with only one active at a time.
For additional information on Regex see @Craige_Hales' blog post and for insights into the Pat Match option see the JSL Cookbook.
By default, I have implemented Option 2: Pat Match for error checking.
  Required Header Items:
  1. Title
  2. Vector
  3. Tuples
  4. Data
  Header Format, i.e., structure of the header attribute
    << Attribute Name >>
    << Vector Number >> , << Numeric Value >>
    << "String value" >>
 Where, |
 << Attribute_Name >> is a symbol/token of (usually) 32 or fewer characters
 << Vector Number >>  is 0 if entire file
 << Numeric Value >> is 0 unless otherwise specified
 << "String Value" >> is \!"\!" (double quote with no space between) if not used
 Optional Header Items: Please note these optional headers were not tested during the development of the add-in
  1. Comment
  2. Label
  3. Size
  4. Truelength
  5. Units
  6. DispalyUnits
 DATA:
 << Data Type Indicator >>, << Numeric Value >>
 Where,
 << Data Type Indicator >> is one of three values -1, 0, 1
 -1 --is a special data value
 << "String Value" >> = BOT or EOD
 0 --numeric signed decimal number
 << Numeric Value >> = is numeric data
<< "String Value" >> = is one of the value indicators (V, NA, ERROR, TRUE, FALSE)
 1 --string data value
<< Numeric Value >> = 0
 << "String Value" >> = string data value
errorhdrchkExpr = Expr(
	regex_hdrs = "(TABLE|VECTORS|TUPLES|DATA)";
	matrix_hdrs = { "TABLE", "VECTORS", "TUPLES", "DATA" };
	rqd_hdrs = { TABLE, VECTORS, TUPLES, DATA };
//	Option 1: Find match using Regex with check for required headers
	thematch = Regex( lines, regex_hdrs );
	If( IsMissing(thematch),
		errnum_desc = "Error: A required header is missing";
		errhdrnum = 0;
		Break();
		errhdrnum = 1
//	Option 2: Find specific match using Pat Match with check for required headers
	err_List = {};
	For( e = 1, e <= Nitems( matrix_hdrs ), e++,
		thematch = patMatch( txtfile, matrix_hdrs[e] );
		If( thematch == 0,
			errnum_desc = Concat("Error ", char( e ), ": ", "A required header ", matrix_hdrs[e], " is missing.");
			Insert Into( err_List, errnum_desc);
			errhdrnum = 0;
			Break();
			errhdrnum = 1
	// Option 3: Find specific match using LOC with check for required headers
	err_List = {};
	For ( e = 1, e <= Nitems( rqd_hdrs ), e++,
		If( Loc( {lines}, rqd_hdrs[e] ) != [1],
			errnum_desc = Concat("Error ", char( e ), ": ", "A required header ", rqd_hdrs[e], " is missing");
			errhdrnum = 0;
			Break();
			errhdrnum = 1
	// Option 4: Find specific match using Contains with check for required headers
	err_List = {};
		If( Contains( txtfile, rqd_hdrs[e] ) == 0,
			errhdrnum = 0;
			Break();
			errhdrnum = 1
Sample.DIF file was used for the development and testing of the add-in.
The contents of the sample.dif file is shown in the attached image with the required headers contained.
File Contents of sample.difFile Contents of sample.dif
The add-in was inspired by the community post from @JensRiege when he asked how to Import .dif file format in JMP Script.
Questions or comments are encouraged.
cheers,
Stan
Comments
JensRiege
6 Stars! (out of 5)
I use this old file format daily since we have some legacy software systems.
Worked extremely well!
Thank you !!!
-Jens
