Hello all, I am trying to look at some Irish data by county. Is there a JMP map of Ireland with county coordinates anywhere? The Street Map Service map isn't doing the trick for me.
The written help (F1 or Help menu in JMP) in combination with the files that Ian has provided may also be helpful.
The article on Custom Map Files and this example on data from a .shp and .db file source describe where you need to place your -XY and -Name files and how to select Column Properties > Map Roles.
