Irish JMP Users Group Discussions
Stefan
Level III
JMP Ireland county map
Hello all, I am trying to look at some Irish data by county. Is there a JMP map of Ireland with county coordinates anywhere? The Street Map Service map isn't doing the trick for me.
Thank you
3 REPLIES 3
ian_jmp
Level X
Re: JMP Ireland county map
I found the ESRI files here. The 'Name' file has some columns that you could safely delete, and you could switch to Gaelic names if you prefer.
@Stefan
The written help (F1 or Help menu in JMP) in combination with the files that Ian has provided may also be helpful.
The article on Custom Map Files  and this example on data from a .shp and .db file source describe where you need to place your -XY and -Name files and how to select Column Properties > Map Roles.
alan_ruttle
Level II
Really good video's that step you through the map building process: https://www.jmp.com/en_ca/events/ondemand/mastering-jmp/using-geographic-maps.html
