Attention all Manufacturing Engineers!
This is a companion activity to the Mastering JMP session Getting a Handle on Optimizing Day-to-Day Process Manufacturing Operations.
During the presentation, a method is presented for using Data Mining to find solutions for root cause of process excursions.  From personal experience I can tell you this method works very well and can help save time and resources investigating possible root cause, helping the team focus on the most likely prospects.  As a follow-on to the discussion and a DIY exercise, here is another example you can try.
So here is the scenario.  During a routine process review, an unusual pattern was discovered between Process Monitor 2 and Process Control 5.  There is a diagonal cluster of points that looks very unusual and the team wants to find root cause for this pattern.  The distributions for Monitor 2 and Control 5 look completely normal, so root cause remains a mystery.  Your job is to use data mining to find root cause for this issue.  The steps to do this are similar to the Mastering JMP discussion, with a couple twists to work through.
Please feel free to enter replies to this post and I will accept the first correct solution.  However, as a spoiler alert, please don't read the comments until you have tried to solve it.  Also, if you have used this technique to solve real world problems, it would be great to hear about that.  Keep in mind, the technique may not uncover an unambiguous answer, rather narrow the list to the most promising prospects, which is still a win in my book.
Good luck, have fun and happy sleuthing!
Hyde
Visualize the Issue
Individual Distributions Look Normal
