German, Swiss, Austrian Discussions
Would you like to present at Discovery Summit Munich 2020?
Submit an abstract showing how you solved a real-world problem with the strategic implementation of analytics in JMP. We want to hear how you are challenging analytic theories, implementing best practices, innovating in your field. If you are selected, you’ll present at the conference 10-12 March 2020 in Munich.
The call has been extended to November 8th.
https://discoverysummit.jmp/en/2020/europe/home.html
0 REPLIES 0
