RiztCL
xgboost_jmp module
Hi!
I while testing the great XGBoost add-in I generated Python code for the model, however I've been unable to run it because it asks for the module "xgboost_jmp" that I cannot find through PIP, please advise, where can I find that package??
Many thanks,
Re: xgboost_jmp module
Hi @RiztCL ,
When I select "Generate Python code...", "xgb_jmp_m1.py" and "xgboost_jmp.py" are generated. It seems that the module "xgboost_jmp" refers to "xgboost_jmp.py" file. You need to put these two files in sama folder to import "xgboost_jmp" correctly.
