Song
why this script is not working??
dd = Current Data Table();
i=1;
newdt&i = dd << Subset( Output Table Name( "i" ), All Columns( 1 ), All Rows( 1 ) );
//Graph table
newdt&1 << Select columns( :As is Config );
this script is  not working at select columns....
please solve it ..
Re: why this script is not working??
You appear to be attempting to use SAS Macro syntax in a JMP script.  &i is not valid for JSL.
One way to handle what you are attempting to do in JSL is
i = 1;
Eval(
	Substitute(
			Expr(
				__xxx__ = dd << Subset( Output Table Name( "i" ), All Columns( 1 ), All Rows( 1 ) );
//Graph table
				__xxx__ << Select columns( :As is Config );
		Expr( __xxx__ ), Parse( "newdt" || Char( i ) )
Documentation on this is in the Scripting Guide.  You need to take the time to read through the documentation.
     Help=>JMP Documentation Library=>Scripting Guide
i = 1;
Eval(
	Substitute(
			Expr(
//Graph table
Song
Thanks a lot!
