billi
Level V
which platform will be suitable?
I have an instrument for which I got certain settings which gives me desirable weight of the product. Is there any other platform in JMP which I can use to estimate cahnces of failing except capability analysis?
Re: which platform will be suitable?
I think that the capability analysis in the Distribution platform is the best method.
Note that it assumes you have normally distributed data. You can instead, when necessary, fit another model and then use the model's red triangle menu to perform the analysis.
billi
Level V
Thank you Mark.
